sbd's avatar
sbd
Wiring for 2 speed Fan
Hello, my motorhome has two fans, 1 facing driver and 1 facing passenger. They connect to 1 switch which has two speeds. The wiring from the switch has 2 yellow wires and 1 white wire going to each fan. The fans have a yellow, green, and black wire. The yellow and green are marked with a + sign.
I had it hooked up and working, but tried the switch again and this time they would do nothing. I had the white connecting to the black on the fan and the green and yellow both connecting to yellow from switch.
What am i doing wrong and did i blow the fans or a fuse maybe?
Thanks for your help.
Sbd
  • Have you reviewed your wiring diagrams?
    Just select your year and model. There's labels on your wires that match the diagrams.
    2005 Itasca Sunova 29R, right?
  • Does the ignition switch have to be on or in the accessory position? If not I would look for a fuse that is bad, since they worked previously. JMO
