lucky13's avatar
lucky13
wiring issue
The 110 socket where my back up camera and computer is not getting any juice,,, is there a separate breaker for this or fuse,,, nothing will work even if I plug something else into it, nor will it work with my inverter,,, any suggestions
  • Please tell us what RV you have.
    And are you sure that your back up camera is 120 VAC-- that would be unusual.
  • Some GFI outlets trip with the small transformers that are used to charge phones and other accesories, I can not charge my phone or plug the computer to any of the GFI outlets, they immediately trip.
    navegator
  • sorry,
    it is a alfa seeya gold,,, and it is the computer and monitor
    and I have checked all gfis
  • Are there any other dead outlets in the RV? The chances of this outlet being the only one on a breaker is pretty small.
    Check in all cabinets, the bathroom, all outside compartments as well as in the exterior door of the refrigerator. I'll bet you'll find at least one more dead outlet and it will be a GFCI outlet that is tripped. Just use a small 120v night light and check every single outlet on the coach.
    If this is truly the only outlet that is not functioning you can probably rule out:
    the transfer switch
    the breakers
    fuses (it's 120v so it's going to be on a breaker
    the shore power cord
    Leaving:
    A bad outlet (Most likely)
    a wiring issue to that outlet (less likely)
  • We specialize in Alfa's MH
    Join this site
    https://groups.io/
    then click here to join the Alfa MH Forum Groups
    https://groups.io/g/alfaseeya/topics
    we have over 500 members easy
