ctilsie242's avatar
ctilsie242
Aug 15, 2017
Worth buying a Hymer Sunlight and upgrading it?
The Hymer Sunlight, which is sold at CW is an interesting model. First, it has a very low price, likely in the 55k-ish range when all is said and done. However, you do get what you pay for, as per the YouTube reviews.
There are a few major downsides to the van:
  • Combined black/gray tank, 23.1 gallons.
  • Trim is "meh" at best.
  • No onboard generator, it uses a secondary alternator.
  • Has a funky, folding wood divider between the bathroom and the rest of the van.
  • No rear backup camera.
    The combined tank isn't too bad an item. The backup camera can likely be wired in. The wood divider can be removed, and a shower curtain placed there. Since the van uses an inverter, the A/C hits the inverter with the locked rotor amps, and not the alternator/generator upstream. This means one can get away with using a 2000 watt inverter generator to run it, so when boondocking, the generator can be placed well away from the van to minimize noise and vibration.
    The main issue I'm concerned about is how the plumbing/electrical/appliances will last.
    The trim level is of an entry level class "C", or a trailer. A concern, because a class "B" isn't something that you keep for 5-10 years then have hauled to the town dump like one does with most new trailer brands. However, it seems decent, especially for the price range.
    I wonder what other people think. For me, adding a Honda generator to keep it powered while boondocking isn't that big a sacrifice for a "starter" class B, which won't depreciate much, especially here in Texas, where ten year old T1N Sprinters still sell for for 50k+ at PPL.
