โJul-13-2018 07:08 AM
โJul-13-2018 04:31 PM
โJul-13-2018 03:50 PM
jplante4 wrote:
If it's a combo unit, make sure it's vented to the outside.
โJul-13-2018 03:02 PM
jplante4 wrote:
We discovered that the seedy underside of campground living was the laundry. It seems to me that the seasonals consider it to be theirs and the transients are merely allowed to use the facilities at the discretion of the seasonals. If you're not there EXACTLY when the washer or dryer stops, your stuff gets dumped (sometimes on the floor) and they commandeer the machine...
โJul-13-2018 02:49 PM
โJul-13-2018 02:21 PM
old guy wrote:
the main problem with a comb washer/dryer is it takes twice as long to do a load of laundry. the dryer portion is 120v and it takes a long time to dry a load of clothes, but on the other hand you need 50 amp service in your rig to operate a stack washer dryer since the dryer is 240v like in your house. if your rig is 30 amp you are then stuck with the comb washer dryer
โJul-13-2018 01:30 PM
โJul-13-2018 01:16 PM
โJul-13-2018 12:57 PM
โJul-13-2018 12:43 PM
โJul-13-2018 12:40 PM
Two Jayhawks wrote:Trigger Happy wrote:
Can the washer dryer units be used while going down the road?
Yes but I don't believe it is recommended. Assuming you have adequate fresh water, adequate room in the grey tank, and running genny. The hitch is, I've heard, is the high spin. The high spin might take it's toll on the unit with a moving coach bouncing around.
โJul-13-2018 11:51 AM
โJul-13-2018 11:22 AM
โJul-13-2018 11:20 AM
โJul-13-2018 11:04 AM
โJul-13-2018 10:58 AM
