RGar974417's avatar
RGar974417
3G/4G ?
I'm not a technical expert so just trying to figure this out.So if your phone shows 4G,is that the speed from that tower? The reason I am asking is because I was at a location yesterday and when I got there,my phone showed 4G. But when I went back on later at the same location,it only showed 3G. So I guess I need an explanation on how this works.
  • Would you please give us the name of the app that shows towers connected too. Thanks
  • wa8yxm's avatar
    wa8yxm
    There are two reasons for what you saw.
    I have one place I park where the phone switches between 3G and 4G.. I have an app on my phone that will identify the tower.. I'm between two towers and one of them is 3G and one is 4G sometimes it connects to the good tower (not often I fear).
    Another reason might be your data plan.. Mine will drop me to 3g if I use too much. But at least I never pay "Overage" fees.
  • If your phone shows 4G, that is the connection technology being used at that moment.
    If it shows 3G later, that is the connection technology being used. It may be the same tower, or it may be a different tower. It may even be a different provider, a roaming partner if your service permits data roaming. It is the connection your phone found. It might be a connection from a more distant tower that stayed connected as you moved, so you could maybe get a faster one by re-booting, or disconnecting and reconnecting data, if your phone allows that.
    If your voice technology is GSM, the phone might also show E, for Edge, which is about 2.5G (actually 3G by global standards, except that someone made 3G a trademark in the U.S. for a specific data technology).
    Some phones show the provider as well. Mine does.
    Sometimes they lie about the provider part, i.e. if the connection is with an AT&T U.S. roaming partner my phone still says ATT rather than identifying the local provider. But when I am somewhere I must pay for roaming, the phone shows the actual carrier: e.g. Orange, O2, T-Mobile, Vodafone, and Telekom have all popped up on my phone the past couple of years.
  • Yes, that is the speed available at that location. You will generally see 4G (great) 3G (OK) or 1X (nearly unusable) and that can vary even when only moving 5-10 miles. It's also possible that an overloaded tower can switch to 3G to keep everyone online but at a reduced rate. The tower has a limited amount of bandwidth available (a lot, but still it has a limit) which must be divided by all users connected.
  • Put your thread title on Google. There are a number of good answers there, more and better than I could post here.
