I'm not sure where to post this as it involves the antenna in our vehicle. We've had a problem with the radio for a while and have finally traced it to a loose connection behind the panel behind our '...
Automotive antenna cables are generally about the outside diamater of RG-6 but..The "Shield" is about the size you'd expect. The "insulator" between the two is a tube.. and the center wire about 28GA likely enameled (or perhaps just bare) if it's enamaled use steel wool to polish the end and solder on.
Basically i'd replace the antenna assembly to get a new plug.. not that expensive if you go 3rd party.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
