Dennis12's avatar
Dennis12
Back up Camera
My back-up camera is working fine until I turn on the turn signals. When it's on the right signal it shows the left side of the unit. Same with when I turn on the left signal it shown the right side of the vehicle. It just started this, Was working fine.
My unit has a AXXERA model # AV614BH
Any info will be deeply appreciated.
Thanks Dennis
  • The manual for your AXXERA model # AV614BH shows only one video input. The rv manufacturer would have to add some type of monitor control device downstream from the one video input to provide 3 camera inputs. You might try to find that device and check connections, switch settings, etc.
    Fred
  • First thing
    Check all your turn signal lamps
    Bad lamp, causing voltage drop on the circuit could trigger this
    If all the lamps are good and work correctly
    It might be the monitor control circuit
    Check your connections and wiring, wet, corroded, loose
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 30, 2025
