darbyjudy's avatar
darbyjudy
cable connection
I have a 2004 Gulfstream Sunvoyager, when I connect to cable the picture on my TV is very snowy. I can use rooftop antenna or sat dish &the picture is great. The connector for cable is located in rear compartment. What would be an easy way to check this problem out?
  • wa8yxm's avatar
    wa8yxm
    Several possible issues: #1 on the hit parade is the first two responses, I'll give them the credit. Other possible issues are dirty/loose connectors, bad coax and staple through the coax shorting it out.
    But I would put my money on the first two responses. User error.
  • X2 on the antenna booster switch being OFF for cable. Most times it is located near the main TV. It's usually a cover with a coax connection, 12v receptacle and a small slide switch.
    Beverley & Ken
