- valhalla360Navigator
BB_TX wrote:
RetiredRealtorRick wrote:
"....If you are in a caravan, you can use apps that let you set up a multi-party conference call group...."
Just like everybody in the caravan being on the same CB channel, eh? :h
Yeah, but no one outside the caravan group getting in.
And sound quality is much better. You can also send text or pictures.
Lost cell coverage is very rare on major freeways and you are unlikely to run into a traffic jamb or hear of issues on the CB if you are off in the backwoods away from cell coverage.
So, yes, you can come up with oddball situations where they may be better but 99% of the time other modern systems are better. - TvovExplorer IIBefore we had kids we used CBs a few times for long trips with friends in different vehicles. It was fun and kept everyone awake.
We used a CB for our first year of camping, 20 years ago. We were usually traveling alone, so I would just leave it on channel 19 to listen. Our kids were under 10 years old, and I quickly stopped using the CB due to language coming over it... I don't know if I just hadn't noticed it previously, but we just stopped using it.
After cell phones became common, we haven't used one at all. - BackOfThePackExplorerIntroduced this past year are a handful of radios (more to come) with integrated DSP (Digital Signal Processing). Literature calls it NRC. The world of Amateur has had it quite awhile, and external devices have been available (I’ve used an amplified DSP speaker the past eight years)
This is the biggest change since the expansion to 40-channels. A level of performance others are unaware exists.
I run a CB 300-days/year, several thousand hours. DSP uncovers the RX your radio received, but couldn’t make legible (audible). QUALITY of what’s heard is significantly increased, and QUANTITY (distance) is bettered. Makes listening all day much easier. (I can run close to wide open all day re SQ and RF Gain).
CB today is for the few. It has no peer, much less any substitute for when it matters most (like a seat belt or pistol). Proper installation and best antenna mount location are key. Quick and dirty delivers terrible performance. Avoid that. Read, make lists, get supply & tools.
www.k0bg.com is the Mobile Radio Installation Bible.
HEAR, AND GET HEARD
1). The latest Stryker HPC (955 & 655), or the ANYTONE AT5555N2.
2). Center roof mount SIRIO 5000 Performer on a BREEDLOVE Mount.
3). (Used) KENWOOD KES-5 mil-spec external speaker mounted just ahead of drivers seat firing into footwell (can listen to NOAA 40-yards from truck you crank it up).
4). Marine-grade wiring & terminations (USCG-spec) POS to BATT & NEG to closest DC ground (think inches, not feet). Encased in split-loom, etc.
It’s common for me to converse easily with another those right around me can’t hear or can’t make out. Easy to alter plans with a heads-up 12-15/miles out versus 2-3/miles. . Big trucks are harder to do, expense is higher, yet it pays for itself 2-3X year (past accounting of crash avoidance).
DISTANT EARLY WARNING.
The phenomenon of SKIP (solar cycle upswing caused) means daylight hours it’s more difficult than just a year ago. Jerks on overpowered base stations with no job except this one. Must pay okay to screw up CH-19 as it’s the Devils work. (Read on, Solar Propagation).
DSP plus a MyAntennas CMC Choke reduces noise such that voices stand out better and audio controls can be set more easily. (Don’t give up: the $250 AT radio & $15 speaker noted are the equivalent of what I spent $600 to achieve).
“Export Radio” (as above) have the wattage to get heard (40-80W). The antenna is the biggest factor, but don’t expect any responses in daylight with 4W. (Scott’s Radios or Walcott Radio; antenna at DNJ Radio; mount at Breedlove).
OWN THE MEANS OF COMMUNICATION.
Ten years or more is a realistic expectation of service.
. - I used to use a CB radio for years - mainly for road conditions. Haven't used one for at least 7 years. However, over the last few months I have remarked to my wife that a CB would be handy as we sat in backed up traffic.
Low and behold, my SIL gave me a CB radio for Christmas. I installed it a couple days ago. Noise on all channels required a LOT of squelch. Not sure if the issue is antenna, radio (Uniden) or environment. We do plan on keeping the squelch turned up fairly high unless we encounter a traffic "situation". - wa8yxmExplorer III
valhalla360 wrote:
Not really.
If you are in a caravan, you can use apps that let you set up a multi-party conference call group, so you don't have to call each one individually.
Traffic conditions are much more accurate with apps.
No harm if you want to get one but the 70's are a long time ago.
They work real good when you are out of range of Cell Towers (Read that they don't work at all if one or more of you are out of range of Cell Towers)
RADIOS... Well my CB's are good to a few miles.. and my ham rigs.. Much farther.. NO CELL PHONE TOWER NEEDED.
Of course when I am in range of a cell tower.. I've a small computer ($10.00 when I bought it) in fact 5 of them... They connect to either my house router or my cell phones wi-fi Hotspot.. And with a 100mW (That's 0.10 watts folks) of RF.. or with one of them not even that.. My Range is..... Well I once ask a ham what time it was where he was (3:10 PM... Strange.. My clock also said 3:10 just AM. - Matt_ColieExplorer IIWe have used all available without an FCC license.
We ran CB for years and then turned it off when it went bad. The capability of an open call is the best part. The coax in the coach got damaged and I haven't replaced it yet, but I plan to.
When we have caravanned, we got out the FRS walkie talkies. They were effective, but the limited range was sometimes an issue. This year, I have to buy a new set of batteries for them.
We have run in convoy with cell phones and on the blue roads it works, but loose the cell and you are done. An open forum app as proposed above does work, but there is no open call available also as mentioned.
To each his own. Everything is a compromise.....
Matt - BB_TXNomad
Yeah, but no one outside the caravan group getting in. - RetiredRealtorRExplorer"....If you are in a caravan, you can use apps that let you set up a multi-party conference call group...."
Just like everybody in the caravan being on the same CB channel, eh? :h - pbeverlyNomad IIWe use handhelds when caravanning. Wife and I use cell phone when backing TT into campsite, however, if there is no cell signal, we use the handhelds. Also use in campsite if some wander off exploring. Phones and apps are great until you have no cell service.
- d1hNomad III
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
