Continuity problem with coax
Silverback98042
The coax cable has a continuity problem somewhere between the connection on the side of the trailer, and the end that is to connect inside. We have had intermittent issues when trying to connect to campground provided cable tv, but can't make a connection now that we're connecting to Dish satellite. Running coax directly to the receiver from the dish works great. The problem is with the internal coax in the trailer.
I guess it's necessary to replace that coax, but don't know how to go about that.
Any ideas?
2013 Ford Superduty F250 Powerstroke CC 4X4 Platinum
2013 Outdoors RV Timber Ridge 280 RKS
19 REPLIES 19
D_E_Bishop
To answer your question and not trouble shoot the problem, go to a true electronics store, either a S&B store or an online store and buy enough RG8 coax cable to go from what ever point you wish to use to your Sat. box, a package of F-Type, RG8 compression connectors(3GHz is what I am using), an installation tool, a cable stripping tool and a external cable connector plate.
Determine where you will mount the external connection point, that will determine what type of wall mounting you need to buy. RV supply stores have a wide variety.
Determine how you will run the cable. While RG cables are not as touchy as HDMI cables about bends, I try to have at least a three to four inch radius to the bend.
Depending on the circumstances, I try and run a piece of scrap wire or weed whacker cord through the route I have selected for the coax installation. Pull it back out and buy a piece of cable 10% longer than the routing wire. I pull a pull wire in when I pull the measuring wire out.
Install the exterior coax connector on the cable end, after having dry mounted the outside connector. remove it install the new connector to the back of the plate and reinstall the plate.
Now go inside and allowing at least 12" and preferably 24" of cable in excess of what is need to connect to the satellite box, install another compression F-Type fitting.
Connect the new house cable to the sat. box, the dish to the external connector and you're ready to go.
You may be able to use a factory cable in the RV, if you do, you don't need much of what I suggested, however make sure any thing you buy is exterior grade. Exterior F-Type connectors come with a rubber seal built in.
Good luck and enjoy the show.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
wa8yxm
I found that there were multiple lengths of coax on my RV, and one of the "hidden" connectors has failed.. I fixed it, but I still have a failure.
The Factory coax usually runs to a switch (Unless you have one specifically labeled SATELLITE TV ANTENNA) and this simply will not work with Sat TV
Also it's often RG-59, not good, very high loss.
Sandia_Man
Satellite TV needs to have a straight shot from exterior coax input to satellite receiver which is usually not the case if you only have a single exterior coax input. It will work OK for park provided cable tv but satellite signals will not passthrough.
My TT supposedly was satellite ready but when I tried to view satellite TV utilizing our single exterior coax input it was a no go since that coax input runs directly to a splitter behind where interior coax connection and tv antenna power button is located.
Most rigs that have a single exterior coax input will have similar issues but there is a simple mod we performed that alleviated this problem allowing us to use the same single exterior coax input for both satellite and cable tv. Some RVs do have a second exterior coax input dedicated to sat tv.
RoyB
Mice loves coax cables...
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Artum_Snowbird
I had the same problem once. I found that the coax in my camper had screw on connectors at both ends. The one at the distribution box had the center pin just 1/32 of an inch too short and would not connect on the box.
I used needlenose pliers to pull the center pun further out of the body of the coax, and everything worked just fine after that.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
