Bill_Satellite
May 03, 2013Explorer II
The HR23 should work. You must first go into the receiver setup menu and set the antenna type to oval 3-LNB and the switch type to multiswitch. Once this is done, go to signal strength and signal meter before turning on the antenna. Now turn on the antenna and let it lock to 101. Once complete you can click the continue buttons all the way to the end.
Just be sure that you go into the receiver setup menu and click on Display>Preferences and then Hide HD channels so your SD channels become available.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
