chezhead's avatar
chezhead
DirecTV upgrade to Genie 2 in motorhome
I want to be able to install a Hs-17 Genie 2 and a C61K wired and a C61W wireless clients in my motorhome. I currently have an SK 3005 Traveler installed on the motorhome using a HR-24 DVR and a H20 receiver. Winegard is telling me that there is no way to upgrade my SK 3005 and that I'll have to buy a whole new SK SWM3 dish. Is that true? I thought that there was an upgrade kit.
  • Winegard is telling me that I need the HS-17 Genie 2 to get 4K. The sales reps appear to want to sell me a new dish rather than give me good answers.....
  • With no need for 4K the HR44 works for us at home and the RV. It's mounted vertically in the back of a cabinet which solves the limited horizontal space in the RV cabinets. The HR54 is similar.
    The Genie 2 size, power requirements and cooling seemed probmatical to me for a RV. Not for cabinet installation, must be vertical, needs power and coax wiring and would need to be secured for transport.
  • Sounds logical but is the SWM LNB a Reverse Band LNB by default or to you have to change that out as well?
    I have found the Genie 2 to be less RV worthy than the Genie HR54 that I have so I have never really pursued what or what might not be necessary for the Genie 2. I guess I don't understand how the Genie 2 stand alone server would dramatically improve what's available with a standard Genie / client combo.
  • They are telling me that I need a Reverse Band LNB and that is what makes it not work with my SK 3005. Supposedly the logic in the turret won't work with that LNB, nor will the electronics in the controller.
    Your thoughts?
  • Just adding a SWM8 kit to the SK-3005 should do it. There's nothing special about the Genie 2 compared to the Genie as far as antenna connections are concerned.
    I assume you know that the Genie 2 does not connect to a TV so you need the Genie 2 plus a client for each TV.
    Did you happen to ask Winegard about the SWM8 kit? They sell it but parts can be found for less online. Be sure that you use the PI29 power inserter. It's possible this could be the complication. I am not sure what power inserter is built into the Genie 2 and if it will pass an external power supply like the standard Genie will.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
