RRodda
Aug 17, 2015Explorer
Dish tv for RV
Do I understand it correctly, with Dish TV for RV programming, the only way to receive local channels is via an OTA antenna?
Bill.Satellite wrote:jackquontee wrote:
On a related note, I believe there is a "coverage area" that ranges approximately 150 mi. I assume this means I can watch my local programming up to that range?
In addition the the correct "Yep" answer, the spot beams can be as large as to cover as much as 500-1000 miles. You may still receive the signal but it would not be "local" any longer. It's just a matter of checking to see if the signal is available at the new location and then making the call (chat appears to be even better).
