RRodda
Aug 17, 2015Explorer
Dish tv for RV
Do I understand it correctly, with Dish TV for RV programming, the only way to receive local channels is via an OTA antenna?
Bill.Satellite wrote:jackquontee wrote:
On a related note, I believe there is a "coverage area" that ranges approximately 150 mi. I assume this means I can watch my local programming up to that range?
In addition the the correct "Yep" answer, the spot beams can be as large as to cover as much as 500-1000 miles. You may still receive the signal but it would not be "local" any longer. It's just a matter of checking to see if the signal is available at the new location and then making the call (chat appears to be even better).
NO, you tell Dish to send you local signals of the area of you are currently in. Then pay $5 per month.
Dish includes the locals in all of their packages at no extra charge. There is also no charge to change your service location as you travel to update the locals. We do it as often as daily.
What Dish does not offer is the Distant Network Services (DNS) where you receive the E and/or W Network programming (i.e. NY and LA) no matter where you travel. This option is still available from DirecTV for $15-$20/month. Since I use a DVR to record what I want when I want so I can watch what I want when I want, changing the locals every time I moved would not be an acceptable option as I would also have to re-program my DVR. I am a full timer (and move often) so my requirements will differ from those who travel part time or only relocate a few times per year or those who don't want/need a DVR.
That's why many DISH full timers get Hoppers -- PTAT (Prime Time Any Time) . . . CBS, NBC, ABC, and FOX recorded auto-magically on 1 tuner wherever you go.
Actually, DirecTV DOES let you change local stations on the fly. It's just much harder to find the right folks that know that this is allowed.
