Mountain_Mama's avatar
Sep 11, 2020
File transfer via Bluetooth
I want to transfer a file from my PC to my iPhone via Bluetooth which they both have and devices are paired and connected. I followed directions from this link:
https://thegeekpage.com/how-to-send-files-to-phone-via-bluetooth-in-windows-10/
It does not show sending. Only connecting and this directly to a screen that’s says it’s not connected.
I am not getting this final message on my phone:
“Now, go to your Phone and click on accept to accept incoming file via Bluetooth.”
Any suggestions??
  • go to the apple app store on your phone and do a search for (bluetooth file transfer) and try a app to transfer your files you can always delete a app that does not work for you then you have to know where the files are transferring to on the phone.
    (the file folder on one of the screens on your phone?)
  • I'm no Apple expert but I believe you need Itunes to transfer files with Apple products.
    Android can transfer files via Bluetooth however Apple does not allow it?
  • wa8yxm's avatar
    wa8yxm
    I have successfully transferred files via BT but it's been a while
    As I recall you need both device open and live
    You need to "pair" them and
    then approve both the send and the receive.
    And then it crashes often as not (I've not had a lot of luck)
  • On 3 occasions I was coerced into helping a friend with an iPhone
    Each time I had to use iTunes on my pc to communicate with the iPhone and complete the task
    I suggest you try that
    I do not have any Apple products, (which is a very closed system)
  • I never use bluetooth for files, I use a direct cable connection. If your iPhone charge cable is USB, just plug that in.
  • My internet at home is not working right now. That’s why I was trying Bluetooth. But, yes, that is what I would normally do. Thx
  • Not a direct answer to your question, but have you tried emailing it to yourself? that's the easiest way I have found to get a file from one device or another aside from cloud storage.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,801 PostsLatest Activity: Jul 05, 2025
