philh's avatar
philh
Aug 14, 2021
Forcing Garmin 890 to a different route?
When I go to pick up 5th wheel, the fastest route will take me through a major metropolitan city that I want to avoid. Modified route will only cost me an estimated 30 minutes or so.
How do I specify specific roads to travel?
  • Add a via point! At times you need to delete it when getting close.
    This is only way I have acheived routing away from questionable areas.
  • Input a set of coordinates to drive to, an address, a city.. whatever.
  • Download Garmins Base Camp software to PC, create route and send to GPS. You can move the routing to anywhere you want. Added step but custom routes.
  • The newer Garmins also have a "Route Shaping" function. You go into a map of your route and touch places you want to transit. The GPS alters the route to go through those transit points. You can also do what I often do... let the GPS set the route it wants and just take the exit where you want to deviate. The GPS will freak out for a while, but will figure it out and recalculate the route. I drove, sailed, and flew for decades before GPSs and can still use a map when needed.
    Rob
    This is what I would recommend. It is how I determine any route for the GPS. I never let the GPS determine the route, as it rarely goes where I want it to.
    And Basecamp is free.
  • I like Second Chance's advice. It's really easy to force a GPS onto a different route... just take the different route, and the GPS is forced to go along! :)
    Rob
    Using Base Camp software might be your best solution but your 890 will allow "reshaping" as Second Chance describes. Much easier to do than setting waypoints with an older Garmin.
