FW's avatar
FW
HD DVRs
Hi; What do I need to add a 2nd HD DVR to an existing single HD24 receiver?
Thanks
  • If he/you are running one cable to an HR24 and recording 2 channels then your antenna is setup for SWM. You just need to get a SWM splitter (2 or 4 port), insert it in the current coax line and run one cable to your current receiver and a new line to your 2nd receiver. All done!
  • I guess so. I don't know the specifics.
  • FW wrote:
    Existing system is single coax to receiver. It has capability to record two shows at the same time. Is there, or what is the splitter I need?
    Does this mean you already have a SWM set up?
  • Existing system is single coax to receiver. It has capability to record two shows at the same time. Is there, or what is the splitter I need?
  • Do you have a SWM or multiswitch LNB on the dish?
    If you have a (multiswitch) LNB dish, you will need to run two separate coax feeds from the dish using B band converters at the HR24 receiver. If you only want to run a single coax you will need a SWM LNB on the dish, power inserter and SWM multiswitch installed in the rig. About $100 investment to swith to SWM. I am in the planning stages right now to put SWM in my rig.
    I'm looking forward to feedback here as well.
  • I want to add hr24 DVR to an existing hr24 DVR.
    Thanks
    If you are talking about a DirecTV H24 (not a DVR, just single tuner) then that's all you have and that's that. If you want a receiver that will allow you to watch and record 2 different channels at the same time then you need to replace that box or add another (now 2 people can watch 2 different channels on 2 different TV's plus record). With the right antenna you could even update to the DirecTV Genie and watch/record 5 channels simultaneously.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
