Sort By
- mr__edExplorerThanks for the replies. I found a simple fix on another forum
"Access contacts page thru Gmail, choose ‘PRINT’ and then change the Printer drop down to ‘Save as PDF’. Select all contacts. Click ‘Save’ and choose the file location you want to save it to.."
I was surprised I didn't think of that. Simple and worked fine.
EDIT: I should apologize to the two above respondents. You were essentially telling me the same thing, but it didn't sink in. :S - BarneySExplorer IIIMr. Ed,
Here is the way I would do it. There may be a much easier way and if there is I am sure someone here will let us both know.:)
Compose -> To -> Select All -> Insert -> Click on top one, hold down "shift" key, scroll down to last one and click on it while keeping the shift key down. Right click with the mouse and select "copy" This will select the whole list and copy it to the clipboard. -> Open word processor of your choice and start a new document. Paste your list into your new document and save it to your computer in the file format you prefer.
I use Open Office Writer for my word processor. I like it because it lets me save files in many formats and also to convert them to PDF's when I want.
Hope this helps you out a bit.:) There may well be an easier, quicker way to do it but this works and is what I have done in the past. I am sure someone will let us know if there is a better way.:W
Barney - CA_TravelerExplorer IIIOpen an Address Book, select all of the contacts and copy/paste the resulting text list.
Update: For current versions of W10 and Thunderbird.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,800 PostsLatest Activity: May 13, 2025
