- TucsonJimExplorer IIGood news Rangerider. Just picked the truck up and it's running good!
- RangeriderExplorerTucsonJim,
The BIOS update worked and I am back in business. Thank you so much. Good luck with your truck. - HappyKayakersExplorer IIIHow old is the notebook? Sometimes they just quit. Make sure you have the maintenance manual downloaded and search the internet for a replacement keyboard. They're fairly cheap and it should take about 1 hr to swap out. Make sure you have a good set of jeweler's screwdrivers.
- TucsonJimExplorer IITypically, you might run into this issue if your BIOS needs updating. Try this:
This is a simple fix.
You will need your product number.
Go to:
www.hp.com/go/contacthp
enter your product number.
click on the updates and drivers. Update your BIOS, when you have finished
you must REBOOT
This should solve it. - TucsonJimExplorer III'm sure you did a total shut down, battery removal and reinsert, and restart?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
