- LearjetExplorer
Mike134 wrote:
Are you using 2 sets of sensors? the set in the picture and a second set clamped on the generator feed?
I'm using a 3rd sensor for the generator...since it's a 120v generator...only need 1 for it.
"OK it just looked like the mechanical interlock was forcing a 2 pole breaker off (the feed from the generator) when the main was on."
The one feed from the generator goes to L1 and L2 of that breaker when on emer power....good eye :) - Mike134ExplorerAre you using 2 sets of sensors? the set in the picture and a second set clamped on the generator feed?
OK it just looked like the mechanical interlock was forcing a 2 pole breaker off (the feed from the generator) when the main was on. - LearjetExplorer
Mike134 wrote:
Learjet wrote:
yes, each panel has its own main breaker
The white/black wires under the cover go to sensors for an Efergy energy monitor system that shows the Watts being used...they just go to clamp on sensor and have no voltage passing through them to speak of....I could clean that up some. I use it to measure the electrical energy use...I have it wired so It also show the generator load when on emergency power. The wires go to a battery operated transmitter that sends the info to a wireless display.
I'm using a 3rd sensor for the generator...since it's a 120v generator...only need 1 for it. - Mike134Explorer
Are you using 2 sets of sensors? the set in the picture and a second set clamped on the generator feed? - mikestockExplorerLooks like you did what I did at the lake cabin, installed a 50 amp receptacle in the garage for my motorhome.
My son can charge his Tesla. It's not quite a super-charger but he says he gets about 19 miles per hour of charge. - LearjetExploreryes, each panel has its own main breaker
- Mike134Explorer
Learjet wrote:
Answers...
Yeah one of the covers looks crooked in the picture...but it is not when closed.
Yes the male cord is a generator inlet, I used the RV 120 Volt 30 amp homemade inlet because I have plenty of those extension cords already and it goes into the 30 amp RV plug on my Champion....thought about improving that in the future.
The square box is a whole home surge protector.
The EVSE is the charging cable for my Nissan Leaf EV.
cleaner pic.
I didn't pick the paint..bought the house like that...the picture below has some reflection from the tail light of my truck on it...FYI
I originally had the sensor outside...but moved the transmitter inside for a better signal...
I see 3- 3/0 cables from each burndy in the wiring trough. Each panel has it's own main breaker? - opnspacesNavigator IIThen the problem is that with the stay at home orders your EV isn't getting driven. Therefore the expensive modifications you did to the house to keep it charged are not currently getting used.
- LearjetExplorer
cavie wrote:
Paying the electric bill for that big ass house.
Last bill ~$104...one before that ~$94...all electric except water heater and cook top. 1 x 5 ton AC/Heat pump. Helps to have all LED or Fluorescent lighting. - cavieExplorerPaying the electric bill for that big ass house.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
