woodhog's avatar
woodhog
I Pad GPS?
Is the Apple I Pad with GPS a fully equipped GPS unit, can you just put it on the dash like an ordinary GPS Unit when it is running a suitable GPS Application?
Does it require any data from a cell phone link while moving to operate the GPS function?
  • The iPad comes either wifi only capable or wifi + cellular capable. The GPS chip only comes with the wifi + cellular models.
    There are basically two types of navigation apps. Apple Maps, Google Maps, and many others work primarily from cellular to download information such as maps on the go (not stored in iPad) and satellite. Cell towers supposedly work faster in locking in a location. The GPS is considered an assist. You do need a cellular plan in order to use them for navigation but you can also use the maps to read and plan if you have a wifi location similar to the way you would on a computer at home.
    The other kind of navigation apps similar to stand alone units like TomTom, Garmin, Navigon, Magellan, etc. have their own data of maps in the iPad. They work without any cellular connection whatsoever and they work well. And you don't need cellular for location. The GPS can do it all without need of cell tower location or even a cellular plan. What it can't do without a cellular plan is access the Internet obviously for extended data some of the programs feature but you are no worse off than a standalone GPS unit you might buy.
    The standalone apps that can use the GPS unit without needing a cellular connection generally are not free and can generally cost from $30 to $60. But then you have everything a TomTom unit can do for that price if you already own a wifi + cellular iPad.
    Last year I drove from Minnesota to Alaska and all over Alaska. I never had cellular once I entered Canada for over 10,000 miles of driving and the TomTom North American app I bought for $30 never failed me. In some areas there were no cell towers for miles even if I desired to pay and use them.
    What you have to understand is some GPS apps can be used for navigation without a cellular data plan but cannot be used unless you own a wifi + cellular iPad because the GPS chip is only in those kind.
  • I believe you need a cellular iPad because they are the only ones that include the gps chip however:.......you don't need the cell connection to be active
    There are map apps that download the map data in the app and don't need a connection to constantly update maps navigon is one there are many others that are cheaper, I prefer navigon but to each his own the free ones ( like google maps) generally need a connection to the net , wifi or cell , to constantly update. Then there are some that can download just a entire route in advance .. As you can see there are many flavors
    To answer your question
    The iPad uses it's own gps chip and does not need a connection other than that to know where it is . it doesn't even need to be " on the dash" to work however is does need a "view" of the sky .. I've held it while sitting in the front seat and it works fine
  • I use my iPad that has cellular capability but no plan. I have Navigon app and it works great.
    Forgot to mention, my iPad sits on the doghouse and has always had a good signal.
  • Only iPads with a cellular connection have a GPS. You need the cell capability to continually D/L maps as you use it - not a good or cheap solution.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,800 PostsLatest Activity: Dec 05, 2024
