JohnG3
Nov 30, 2013Explorer II
I replaced our Batwing with a Jack. Before making the switch I did a simple test. I cranked up the Batwing and did a channel search with the booster on. Got 8 channels.
I changed out the batwing to the Jack. Same test, same position on the mast, ONLY change was the antenna. Channel search showed 23 channels.
This was done in Morro Bay, CA in an area where the local NBC channel is very difficult to get because of the hills. NBC signal was very good after the Jack was installed, not on the list with the Batwing.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
