TenOC
May 12, 2016Nomad
Map program to display GPS of cities ONLY
I am using BaseCamp 4.6.2. I have an usual requirement. I want to display a map with CITIES ONLY. No roads. Is there a way. Currently I use the "lowest" display setting but this does not display the cities. Any suggestion ???
Can you suggest a different mapping program (cities only) that I could export the waypoint to?
