- DiskDoctrExplorerAlso left Millenicom when they raised their prices. Wasn't competitive for our varying usage. 4G is worthless in most areas we go.
I think they hurt themselves by bumping out of the sweet spot usage/cost wise. - Robin1953Explorer
lryrob9301 wrote:
I had Mellenicom and was leaving 10 to 12GB on the table each month. When they raised it from $70/mo to $90/mo I switched to ST as well. Like you I didn't need the 4G speeds either.
Since we only use around 3-4gb a month, and don't require a super fast connection we use a Straight Talk America MIFI from Walmart. 3G speed on Verizon's network for $40 per month. - TechWriterExplorer
vermilye wrote:
It depends on your data usage. Over 10GB per month is generally less expensive through Millenicom.
Up to a point.
We're full timers who use a lot of data per month. We've been using a combination of Verizon + Millenicom data plans -- typically, 14-18GB from Verizon + 20GB from Millenicom.
However, when Verizon lowered the price of their data plans this month, we signed up for a 40GB plan just through Verizon & saved about $80/month. - lryrob9301ExplorerSince we only use around 3-4gb a month, and don't require a super fast connection we use a Straight Talk America MIFI from Walmart. 3G speed on Verizon's network for $40 per month.
- vermilyeExplorer IIIt depends on your data usage. Over 10GB per month is generally less expensive through Millenicom.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
