Germania's avatar
Germania
Mounting 32" Samsung TV on ceiling
The instruction for this TV tells me not to mount it at greater than a 15 degree angle. Anybody know why ??
I have a ceiling mount that will let it fold up against ceiling (horizontal ) for transport, but I'm wondering if that is going to damage screen.Any input would be appreciated
  • Ivylog's avatar
    Ivylog
    If the TV is above the mount when stowed I would not worry about it. If the TV is below the mount then I would incorporate the base mounting bolts into the mounting.
  • If it's a liquid crystal display (LCD) television...maybe if you mount it on the ceiling, the liquid in the display will leak out.....:B
  • This is purely a guess, but I would surmise that the mounts are made to support the TV vertically. The mounts are probably not designed to support the weight of the TV if it's not vertical - the mounts could/would pull out of the case when it's horizontal, but when vertical they have the benefit of the TV's case for support. Think sheer force required to break it versus pulling force.
  • I imagine it has to do with mechanical stress on the mounting holes. They're probably only set into the plastic frame, and mounting at a more severe angle might over-stress the holes causing the screws to rip out and the tv possibly falling.
    if you have some sort of strap to help support the weight while the tv is stowed, i'm guessing it wouldn't be a problem.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
