roachcoach's avatar
roachcoach
MV 3500T WINEGARD
I have trying to get my rear br tv to work again . I changed zip codes and the rear tv never did work . We have Direct tv and everything worked fine before changing zip codes. I have a 3500t Winegard receiver and have HR 23-700 Direct receiver up front that works fine . The problem is the HR 24-100 in the rear br giving me the problems . I would like to know if anyone has this setup and what your satellite settings are . I have my satellite set to Dish Type :04 Slimline-5 , switchtype : 02: Multiswitch, Tuner : Single,
Hope you guys understand all this
  • "It can", but it cannot work without the addition of the DirecTV SWM8 hardware and the dome (no dome) can receive the DirecTV HDTV programming.
  • I been wanting to get the Geni from Direct , can that work with MV3500T Winegard Satellite?
  • Multiswitch is your only option unless you install a SWM8 switch and I don't think you want to go that route unless you want to be able to use both of your DVR's and their 4 available tuners.
  • Both dual tuner receivers would need to be set to single tuner and I would recommend that you set both to 18" round (others will work but Slimline 5 would not be recommended). Each receiver should have only one cable plugged into the Tuner 1 port and each of these must run directly from the antenna to the receivers.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
