Outdoor WiFi antenna
Retired_andLove
Trying to figure our what I need to put up a outdoor WiFi antenna in our park. I would like to set up a wireless router so two laptops and a printer can connect. Be specific if you can. i haven't been able to figure it out by reading.
Randy & Dianne
2013 Tiffin Allegro
12 REPLIES 12
wa8yxm
Right now on the back of my RV, strapped to the ladder is a flag pole.. no flag, though there is a Linksys WGA-54G on top of the post, somewhat weather proofed. and with a "Cantenna" mod to make it directional.
This feeds the Belkin inside the house (motor home)
Which is feeding (Among other devices) this laptop.
The Belkin router (And I might all routers) think the WGA is a cable Modem and treat it as such.
Set up is a bit of fun as I have to MANUALLY set the IP address for the wan side of the router in order to access the router's set up, and in a few parks something weird happens and keeps me from accessing the router.. though it works.
But you should be able to figure it out.
sonnyw
Look at www.wifiranger.com I have been using the Go to connect all of our devices and very satisfied. Thinking about adding the Mobil to my Go. Folks at wifi ranger very helpful.
Sonny - That's Me
Pat - My Wife, My Best Friend
Bella - My 4 Legged Friend
2016 Dodge Ram 2500 6.4 Hemi
2014 Viewfinder Signature VS-32RLSS - The Old Folks Home
WiFi Ranger
Progressive Industries
1971duster340
For years been using
EnGenius EUB9603H Wireless USB Adapter
EnGenius EAG-2408 Outdoor Antenna and Trend SMA to N type feedline inbetween. It's not exactly the setup you ask about. EnGenius has been expanding their product line to reel-in those weak Wifi signals. http://www.engeniustech.com/
Greg
N5LFH
2007 Chariot
AllegroD
Mandalay Parr wrote:
Retired andLoveIt wrote:
Am I on track with this combo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833164156
This combined with a wireless router that has a removable antenna to connect a N cable.
Not sure.
Did you look at what I recommended?
Go to Hawking web site and look at all possibilities.
Jerry Parr
x2
You are on the right track but take a look at the Hawking site for all suggestions. I opted for an omnidirectional 15db on my last setup.
Does it have to be an outside antenna? What repeater do you have?
Mandalay_Parr
Not sure.
Jerry Parr
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
Retired_andLove
Randy & Dianne
2013 Tiffin Allegro
Mandalay_Parr
I have a Hawking Repeater Router HAW2R1. It works really well. It picks up weak signals from the RV park, amplifies them and it includes a router just like you want.
Jerry Parr
Full-time
2005 Mandalay 40B
2004 CR-V Toad
jrparr@att.net
602-321-8141
Kenwood Radios
GaPete
If you are connecting to a distant WiFi source, you need to not only receive the signal but also be able to transmit back to the source, as I understand it. Wifi is a 2 way process. JMHO
Bill_Satellite
Are you the park internet source wanting to share with others or are you a camper wanting to receive a WiFi signal being broadcast from the park office?
Can't we all just get along?
MrWizard
Moderator
Moderator
assuming you mean you want to 'connect' to weak park WiFI
and have the router inside the RV for the PC's and printer
you want a Wifi "REPEATER" connected to an external antenna
often called a "range extender"
hawking has one called the HWREN1, mine is several yrs old and there are newer models available
you connect one PC via ethernet cable, to do the setup and choose the camp wifi to be 'extended'
after that your PC's , pads, phone etc. connect via wifi like any access point
I can explain it to you.
1997 F53 Bounder 36s
wkswenson
An example of one antenna that may work if the cables will work with your router...
Example Yagi Antenna
Walter & Donna Swenson
2013 Cedar Creek 38FL - Front Living, Trail Air
2011 Dodge RAM 3500 6.7 CTD DRW CC LB
Our Website - "A Work in Progress"
wkswenson
Not sure what you want to do but I assume you have a WiFi Router and want to extend it's outdoor range?
Details
You will need an outdoor grade antenna that works with your router, but your router will need external antenna connections available as shown in the picture.
