MrRules's avatar
MrRules
Voyager AOM713 Problem
The backup camera on my Voyager AOM713 started to come on and off, then started to blink, and now it has gone off completely! I have checked the connections at the camera and at the monitor and they seem fine. The side cameras still work appropriately, it is only the backup, rear view, camera that is troubling. And ideas on where to look for the problem would be appreciated.
Stu
  • backup cameras are triggered to come on when the backup lights are turned on as you put it in reverse i would check that connection. manual and troubleshooting guides here Manual, Manuals & Guides
  • When you say "off" just no display? Are you sure it's not the monitor itself? We had the same monitor setup and replaced it through rvcams.com with an LED flat panel monitor. I bet a call to them would get you more help. They were extremely responsive to my questions.
    If you can get to the back of the monitor easily I'd first try swapping out the cable location from the back to one of the working sides to see if you get a signal there. This is just to check if the issue lies in the monitor or the camera.
    As a side note. I replaced the rear camera with a color camera when I replaced the monitor.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,800 PostsLatest Activity: Dec 05, 2024
