garry1p
Feb 27, 2018Explorer
The brick (inverter)also acts as a regulator so by passing the brick into another 12VDC sources will give you unregulated 12VDC not sure how much tolerance the TV would have but the RV converter will put out over 14V at times.
If the TV comes wired for 12VDC and can be plugged into a 12V outlet it will have an internal regulator.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
