ktmrfs
Feb 28, 2018Explorer II
yes, Jensen makes 12V TV's.
many of the others even though they plug into the wall, run off 18ish volts, likely the same brick used for the majority of laptop PC's which often use 18ishV chargers.
so one could likely use a laptop charger with 12VDC in and the correct mating plug for the TV. I looked at that and decided to just keep using the inverter I installed in the trailer.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
