Bill_Satellite
Mar 15, 2018Explorer II
The Shaw unit is sold as 2 separate parts numbers because you can't get all of those parts in one box. The antenna and associated hardware is huge and that's what the 2nd part number is. However, the base is setup with the correct hardware to mount the Shaw antenna only so while I am sure it could be done you would need all of the DTV parts from the arms all the way up. It's also possible that the electronics are different inside the turret as Shaw uses significantly different broadcasts than Dish or DirecTV and if that's the case then there is NO interchangeable option.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
