path1ExplorerJan 27, 2018Anode questions.1. How tight do folks tighten your anode? (I use Teflon tape on threads and screw it in till finger tight, then little tiny two finger tap on end of socket wrench). 2. When not in use I drain...Show More
memtbExplorerJan 27, 2018I also screw the rod back in partially. Never know what might enter. Once I found a dead snake in a residential house disconnected propane line. A “Sewer” Snake? :h
Related ContentAnode rod question?Stripped Anode RodWater heater anode questionAnode RodSacrificial Anode
