JohnG4706
Feb 14, 2015Explorer
Battery and Battery Box
OK, took the battery out and brought it back to the house to start charging. Voltage read was 5.5V. Will keep my fingers crossed that I haven't ruined the battery.
I also have the Marinco 701 Contour Battery disconnect switch, which I will install in the battery box top before I take the battery back.
Which line should be used for the disconnect? + or -, or doesn't matter?
When I took the battery out of the battery box, there was 3/4" of water in the bottom of the box. Apparently, water entered through the two vents in the lid. Can I just drill a hole in the bottom to drain? Or is there a reason not to drill the hole?
Thanks.
Thanks.
