IDoMyOwnStunts's avatar
Mar 09, 2016
Charging the battery
I'll put this in beginning RV because I think these are beginner's questions and I'm relatively new at this compared to some of you. If it's the wrong forum, mods please move it.
My system is two 12V batteries, a 4000 Watt generator, and a 200 Watt solar panel plus a battery disconnect switch. I don't have an inverter on my rig, so I can't use 110-120 when I'm not running the generator or on shore power. The generator, shore power, and solar will recharge the battery.
Can I use the solar to maintain the battery during storage? That would mean leaving the disconnect shut. As far as I can determine, the CO detector, thermostat in the off position, and 12V entertainment center (maintains time when turned off but connected to power, just like a radio in a car) are the only parasitic loads if I turn everything else off. The fridge power is a physical switch.
I recently found my truck wasn't supplying accessory voltage to the 7 pin and I've rectified that (was missing a relay and fuse. Thanks Ford for not including that with the truck! /sarcasm). Now that I do have accessory voltage, will the truck charge the batteries on the road?
Is there any harm in running my generator on the road to give it some run time? Can I run the AC on the road to give it some load?
My plan in the future is to increase my battery capacity and add an inverter. I would like to be able to watch a movie with the family at night, but I'm thinking that it may be possible to add enough to run the microwave. Is this doable in a travel trailer?
Thanks in advance for any answers.
