- ReneeGExplorerJust an FYI, we just left West Yellowstone. Lows were in the low 30's and highs in the 70s. It warmed up quickly each day. We dry camped at Baker's Hole and set our heater thermostat to 50 each night. No problem with freezing. It has to stay at freezing Temps night and days consistently to worry.
- harold1946ExplorerIn temperatures below freezing we have the water lines to our stock tanks running at a fast drip, sometimes 24-7, throughout the winter. never had one freeze up in 20 years. Livestock need water year round. Every ranch around us does the same.
Its an easy and simple solution rather than dead cows.
When trick tanks and ponds freeze over we need an alternate way to water livestock. - Vulcan_RiderExplorer
harold1946 wrote:
a dripping faucet will help to delay the process buying time in freezing temperatures.
Moving water is moving water, whether in a pipe, stream or a river, and the freezing process is the same. That's how it equates.
No it isn't, not it won't. Simple movement will NOT DO ANYTHING to delay the freezing. Repeating your wrong information a thousand times won't make it any less wrong. - harold1946Explorer
westend wrote:
Guys, reading from a fella' in FL and another from AZ having an argument about freezing pipes is almost laughable.
Not to sat that you both don't have experience but all the OP needs to know is that if the temps dip much below 32 and stay there, some thoughts about winterization would be in order.
Advise was given to the OP and a short message about winterizing and where to find more detailed information.
I don't know about laughable but it has been quite entertaining for me. - westendExplorerGuys, reading from a fella' in FL and another from AZ having an argument about freezing pipes is almost laughable.
Not to sat that you both don't have experience but all the OP needs to know is that if the temps dip much below 32 and stay there, some thoughts about winterization would be in order. - harold1946Explorer
Vulcan Rider wrote:
harold1946 wrote:
Wrong again: I did not make that statement, DSDO Don did.
Read more carefully.
It is not " an old wives tail". It can freeze but it takes much takes longer because the molecules are moving faster and the cold water is being replaced with warmer water continuously.
So you just like to create pointless arguements; that adds a LOT to the forum......NOT.
To try and equate a dripping faucet to a running river is ludicrous.
The one making it an argument is yourself, all that was need was to ignore it if you do not agree.
The point was moving water takes longer to freeze and a dripping faucet will help to delay the process buying time in freezing temperatures.
Moving water is moving water, whether in a pipe, stream or a river, and the freezing process is the same. That's how it equates. - Vulcan_RiderExplorer
To try and equate a dripping faucet to a running river is ludicrous. - harold1946Explorer
Vulcan Rider wrote:
harold1946 wrote:
In a previous post you stated that a fully charged battery would freeze at -60F.
I said ABOUT -6OF....and if it is not quite fully charged that might be the magic number.
I'm not going to argue with you about other things because my only quibble is your statement that "moving water won't freeze". That is patently absurd.
It is not " an old wives tail". It can freeze but it takes much takes longer because the molecules are moving faster and the cold water is being replaced with warmer water continuously. Letting a faucet drip allows the water to be in continuous motion slowing down the freezing process and can keep pipes from freezing. The same reason rivers freeze over but the river continues to run.
I guess you must now also agree that P-traps can freeze and rupture. - Vulcan_RiderExplorer
harold1946 wrote:
For those that have been following this thread please take my advice.
Perfect post. I absolutely agree.
I never DISagreed with anything except the idea that leaving a faucet drip will prevent the pipes from freezing in a small scale, single family residence environment; it just won't move enough water to prevent freezing. It will, however, USUALLY prevent the pipes from braking if they do freeze. - Vulcan_RiderExplorer
About RV Newbies
4,030 PostsLatest Activity: Mar 20, 2025
