thehippie's avatar
thehippie
Dometic heater
When I turn on the dometic heater on my rv, the aircondition would also turn on.
Anyone experienced this?
  • Place the fan control on the thermostat on "AUTO".
    YEP^^^
    Fan control on thermostat is for the A/C Unit Fan.
    In Auto the Fan runs when A/C runs
    In Manual (high or low) fan runs when A/C runs BUT will also run when furnace runs.
    Idea is A/C Fan 'helps' circulate the warm air from furnace (heat rises)
    But in reality it just cools the wram air and provides no benefit plus it's noisey.
  • Is the "Dometic heater" perchance a heat strip on the air conditioner? If it is, the fan needs to run for the heat to work.
  • Go to the wall thermostat and push the Mode button until the green light is on in the Fan Position. Use the +/- arrow to move the selection to Auto. You currently have it set to LO or HI.
  • Old-Biscuit wrote:
    YEP^^^
    thanks
    Thanks
    Thanks
  • just went through the same issue with my brother on his trailer with the dometic thermstat and AC. yup, set it to auto made it work like one would expect.
    oh, and if for some reason the display changes to degrees C instead of Degrees F, (or vice versa) push the up and down together and hold and it will switch.
