DrewE wrote:
What leads one to believe the seals on the drain valves need moisturizing and lubrication? And, in any case, what keeps the seals on the output side of the gate wet and lubricated if that were indeed necessary?
There's no harm in having antifreeze there, but it's not at all necessary.
Since you are asking... and no one said necessary. I will say, from experience, "helpful" in keeping seals from sticking. I have 3 tanks, all enclosed, with cable operated valve gates. I blow lines first, then run about 2 gals of Prestone RV through, catching what is mostly pure AF. I also drain, and catch AF from low points. I will dump about a gal in the black tank, rest in the gray tanks. Come Spring, all valves, especially the black, works very easily, better than during camping season.
I always cover the toilet seal with AF for Winter storage too. It will add longer life too! Necessary?? Maybe not, just good idea.
Thetford, and others, make a valve seal lube, to add to the tanks. Might be worth a try, if you have an issue.
Jerry
