Ponylady97's avatar
Ponylady97
How to drain fresh water tank?
I have a question, I have a 2017 Coachman Leprechaun 260QB and I am trying to drain the fresh water tank. I have located the valves in the pictures but not sure what to open and/or close. I believe the 4 lines with the valves are my low point valves but not sure why there are 4 and should I open all of them to drain the fresh water tank? The other valves attached to the water are all open except one and I don't think I need to do anything to these to drain the tank. Any help would be appreciated, thanks.
  • In order to drain my fresh water tank I have to open all 4 valves at the low point, thanks for everyones help...Happy Camping!!!
    • MNtundraRet's avatar
      MNtundraRet
      Navigator
      Thank you for letting us know everything is fine.
  • Its possible to have 4 low point drains. However they have nothing to do with the draining of your fresh water tank. Take a look under your unit, what do you see as far as hoses coming through the floor. The fresh water drain value could be almost anywhere, but it will be by itself. Does not your owners manual help with this issue.
  • The Styrofoam-insulated tank looks like your hot water tank with the three valves set for normal use.  I can't tell what the picture with four water pipes with valves is, I don't have something like that in my camper.
    My low point drains do not have a valve on them, just a screw-in cap.  they just drain the plumbing lines as open spaces describes. They are located on the outside underneath the camper.  My freshwater tank also has its own drain hose with screw-in cap (no valve) located outside underneath the camper.
  • I don't think those valves are your low point drains. I have one low point drain per fresh water tank. They're very low and BELOW the fresh tanks.
  • On mine the low point drains are just the low points of the plumbing. But the actual tank is below all that. So there is a second drain by the tank to drain it. I would look around the edges of the body to see if there are any more valves.
    I never drained ours except at the end of our camping season. I just pumped the water into the holding tank by turning on a few faucets. If you have low-point valves emptying under the trailer you can drain the lines, there.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
