I wonder if this thread has attracted only those with good experiences. I have talked to a great many RV owners and the majority seem to have numerous repairs and quality issues.
I think I have a well built RV but have still had numerous issues. I bought my Northstar Igloo truck camper in 2010. It was a very, very lightly used unit built in 2005. Before I took delivery the dealer replaced the kitchen faucet and the bathroom vent cover. I used the unit for 2 years fulltime and have at least another full year of use spread out from 2013 until present. Here is my list:
A 45 degree router had been used on the edges of the kitchen counter top to make an attractive bevel. That exposed the underlying pressboard substrate which immediately swelled on contract with water.
The exterior vent flapper for the range hood broke. The hinge pins were 1/16" plastic. The replacement soon broke and I had to rig a repair with metal hinge pins.
The dealer typically installed propane refrigerators. Mine was a 12v compressor. There was almost no ventilation and I had to saw and opening and install a suitable vent. Wiring to the refrigerator was 10 gauge. Again the dealer had no experience with compressor refrigerators. Since the wiring run was about 15' in both directions, 30' total, there was a huge loss of voltage and the fridge would stop working whenever the battery voltage dropped to about 12.5. I installed 6 gauge wiring which immediately fixed the problem.
My Atwood water heater only fired up intermittently. The dealer cleaned the flame sensor. It turned out that my model had an issue with the connectors to the electronic control board. I finally identified the problem and when the unit does not light, I go outside and jiggle the wires. I put an office binder clamp on the connector that more or less fixed the problem.
The cover on my Coleman A/C unit was ripped off by winds that were probably in the 60-90 mph range. The cover was only held by 4 bolts and the plastic just tore loose. A dozen pieces of bailing wire fixed the problem.
I developed a leak in the sealant around one of the windows. It was really tough to find the problem but the fortunately it the fix was pretty quick but not possible while traveling.
I have 4 windows around the bed area. They could be held in two different open positions by use of the strut which contained spring loaded ball bearings. Over the past few years each of these assemblies died when the plastic parts deteriorated due to heat and UV light. Replacements for these simple parts would have cost $500 so I use office binder clamps when I want to hold the windows open.
I have Happijaks to raise the camper off the truck. Two of the motors have shorted out and needed to be replaced at a parts cost of about $125 each. I understand this is a common problem.
The Happijak motors have little boxes for the electrical connections. Those are located on the exterior of the camper. The dealer installed these upside down so that the hole for the wires was on the top instead of the bottom. Eventually the box developed a leak around the wires. Water ran down the wires, into the box. Water filled the box and spilled into the storage compartment that comprised the lower right hand corner of the camper. I discovered this after the winter of 2014-15. Several large structural pieces of wood were rotted and the repair took me two full days of nasty work.
Last Spring my city water connection started to leak. I think the valve was destroyed due to trapped frozen water. It did not help that the valve pointed downwards and there was no way to get antifreeze into it. I guess this one was my fault for doing incomplete winterizing. I did find that the valve was the first piece in the construction of my camper. Everything seems to have been built around it leaving no place for access and replacement. After a days work I just capped off the city water line. I had only used it once but it was a nice backup. Now if my water pump goes I am done for. Speaking of the water pump, it started to leak and fail so I replace it.
The pigtails on my propane tanks dry rotted and cracked. I had to replace them soon after I bought the camper and again a couple of years later. I check them every year and carry a spare just in case.
My solar controller died and had to be replaced. I thought I lost the batteries as well but it turned out that the 19 volt battery readings was just part of the controller failure.
The plastic drawer glides for one of my kitchen drawers broke and the drawer would not work until I installed the replacement parts. I could only find the same cheap plastic parts so I wrapped mine with a few layers of fiber reinforced packing tape.
I envy those of you with extensive RV use and no issues. I do bet most RVers have at least as many issues as I have had. A lot of the failures and repairs I have had are due to failure of standard parts found in most RVs.
