njtony
Jan 12, 2014Explorer
heated water compartment
Well you just have to find out the hard way sometimes ! I 2013 cook up coachman Mirada with heated basement. But just found out the heat does not go into the water / waste compartment. DuH ! 6degrees in nj and water lines froze up. Just like water heater, ( it also froze up) there is no heat supplied to these area's. I was lucky and caught it before anything broke, still need to check water pump. You SHOULD NEVER believe a Salesman. I now have a small heater,but need to figure out a way to control temp our find a different
heater. The one I used is a constant on that came out of my bunk area. maybe its time to trade up again ? but no coachman or forest river.
