help in deciding A or C motorhome
southman
Just retired and plan on getting small motor home. Use will be travel on what we call "back roads". I E route 66 route 30 etc. Do not plan on spending more than a few days at any one location, but want to travel to all 48 lower states and fish along the way. We see advantages to both A and C units. Any help by those who travel as we plan to would be appreciated.
18 REPLIES 18
Mandalay_Parr
It is very hard for us to answer that.
It is so personal.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
RoadAbode
Welcome Southman! Sounds like you are not planning full-timing, (maybe part-timing?) and travelling with just you, your partner, and maybe occasional friends? If that's the case then I'd say a small C or even a B+ might fit your needs. No need for a toad if you are looking in the 24' to 27' foot range. We do pull a toad with RoadAbode, but that's more of a convenience factor with our girls, and not wanting to break camp when we go out. With a B+ or a C, you could just about park right close to those fishing spots. You are giving up some "living room", but if you don't mind being together, it can work. With a slide, you'd probably have more room than we do in RoadAbode with no slides at 29'. If you already have a pickup, Truck campers are getting really comfy these days too.
You got options, and that's a good thing! Good luck, and Peace,
RoadAbode
The RoadAbode Crew
Mike ~ Amy ~ Kimberly ~ Emily ~ and Molly the pup
RoadAbode Blog
toedtoes
How small do you want to go? Under 25 ft? Or more like 28-34 ft?
You don't necessarily need a toad if under 25 ft.
I suggest you go look at floorplans for both As and Cs. Find your favorite floorplan for each type, then test drive them. That will give you a place to start a comparison.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
newman_fulltime
You might do better with a 5ver as with a A you need a toad or rent a 5ver is easybenough to hook and unhook
