Djuanless's avatar
Djuanless
Locating water pump fuse 2007 Sunova
We have a 2007 Itasca Sunova T33 and the water pump is not working. The manual shows an in-line fuse on the pump. We have looked all over the coach even removing drawers and panels and can not find the darn thing. Can anyone offer any help on this
  • On my rig the only water pump fuse I ever found was located on the DC distribution panel.
  • If it has a 120 volt to 12 volt converter, there are usually fuse's loacted there too. Under the cover, sometimes has a knob on top.
    Hope this helps Bob
  • Pump is going to be very close to fresh water tank. In-line fuse will be at pump
    Most likely Service Center in outside compartment -----behind the panel
