mowertech wrote:
Of course, I do not know anything about any RV that I have never owned, but every one I have ever owned (including our current Southwind) had a P trap under the kitchen sink, the bathroom sink, and the shower, and a water seal in the toilet.
Here's a news flash for you that you can even check. See >>.
That seal and a bowl filled with water is ONLY good when the toilet is not being used.
Flush that puppy and the entire time that blade is open its a straight shot to the black tank and during that time stink, smell, bacteria and most likely sewer flies go right into your RV. WHEN you leave the black tank open to the CG septic tank.
ktmrfs wrote:
IMHO NO for BLACK AND GREY!. Why, with the tanks open there is NO p trap between the sewage system and the trailer. so.... no there is a open path between the sewage and smell.
X2
P-traps For sinks yes, for toilet NO!
The toilet itself DOES NOT have a p-trap. When that flap opens its a 'straight shot' to the black tank.
1. First of all 'leaving the valve open' all the poop will just sit on the bottom of your black tank and NOT in any water and build up and build up to a mountain of poop you will never get out of that tank.
It can't make its way out of the tank because there is no water. That tiny amount of water that is put in toilet during flushing, does absolutely nothing to get it to move out of the tank when valve is left open. So it just sits there on the bottom.
2. Because there is no p-trap like in a residential toilet sewer flies, smell from your poop just sitting on the bottom of the tank AND the sewage smell and bacteria from the CG septic systems comes right into your RV every time you flush.
Example. When I am boondocking and want to stay to the enth degree before having to break camp to dump?
>>I first shut the water pump off. I step on the toilet pedal to open flap and shine a flash light down the toilet bowl hole. I can SEE how much is in the tank and how close it is to coming up into the toilet.
So NO there is no p-trap in the toilet. Leave that black tank valve open and every time you flush you are allowing everything that is in that CG's septic tank into your black tank and into your RV when you flush!. :W
