KRex-Tampa
May 17, 2015Explorer
Making Sure I'm Setting My Tire Pressure Correctly
I want to make sure I'm setting the tire pressure correctly on my Fleetwood Storm.
Here are the numbers:
Front GAWR - 7,000 lbs.
Rear GAWR - 12,000 lbs.
Actual Weight Ratings Loaded for a Trip:
Front Axle: 5640 lbs.
Rear Axle: 11500 lbs.
Bridgestone Tires: 245/70R 19.5
Min. Tire Pressure 80 lbs.
Max. Tire Pressure: 110 lbs.
I looked up on the Bridgestone Web site and found the following
At 80 PSI for Single Tire it is showing 3525 lbs.
At 80 PSI for Dual Tires it is showing 3415 lbs.
If I take the front Axle actual weight and divide by two I get 2820 lbs.
based upon the information above, I would set the tire pressure to 80 lbs. cold (or a little more to keep above the 80 lbs min. PSI on the tire).
If I take the rear axle actuals, and divide by 4 I get 2875 lbs.
I know that I should weigh each tire individually, but I currently do not have access to a scale to make sure a weighing.
Am I calculating this correctly, so that all tires should be set to between 80 lbs. and 84 lbs. ?
