path1's avatar
path1
Normal or not? Hot water heater on elec.
When hot water heater is on elec is it normal for it to make grunting noises? I assume the element is heating up and making the noises?
I've flipped the pressure relief tab several times and can't think what else I should do, if anything.
Is this normal or not?
  • Ours did that on the first night we had it. We ordered it new. Sometimes it is worst than others. Changing the anode rod helped but not always.
  • Old-Biscuit wrote:
    Element is scaled up.....noises are from element heating and scale popping
    Might want to re-establish the 'air pocket' cause flipping the T&P Relief Valve open has most likely gotten rid of 'air pocket'
    Air pocket is used to absorb increase in pressure due to water swelling when heated. Air can be compressed.......water can't
    Turn off water supply
    Open nearest faucet hot side to relieve pressure
    Open T&P via lever until water stops flowing then let it Snap closed
    Close faucet
    Turn on water supply
    Thanks...
    Should this be done every so often or when it starts making noise? Or what do you recommend?
    I clean out hot water tank probably atleast twice a year. Noise is not very loud but didn't know if normal or not. Sounds like a tea kettle warming up.
    Thanks again
  • Element is scaled up.....noises are from element heating and scale popping
    Close faucet
