โOct-26-2014 04:46 PM
โOct-28-2014 10:25 AM
โOct-28-2014 09:44 AM
jadatis wrote:
@Terry And Kim
No you want to devide the whole weight of car over 2 tires but a car has 4 tires so devide that 5740 lbs by 4 so 1435 a tire.
This would give 40 psi in my list.
But the weight is unequally devided over front and back , so that is why my first given advice is different front and back.
I also daubt that if you are fully loaded , that your weight is that 5740lbs. Practice prooves that weights are always yudged to low.
Best advice would be, and probably also already given in this topic, to weigh per wheel in the loading you drive, and use those weights to determine the needed pressure. For each axle use the highest weight for calculating
@ Diskdoktr
Up to 2000 the tire and car makers also gave these low advices, so they thought it to be save too.
And also Goodyear still gives a list for ST tires that goes as low as 15 psi still on a page with Pressure loadcapacity lists.
Then I am refering to this page
The ST list at the top
I already mailed them about it to be verry unsave because they calculate these radial tires with the power 0,585 wich is meant for diagonal tires. But they are hiding behind TRA and sticking their head in the sand.
I think the Ford/Firestone affaire, in wich more then 100 people died because of roll over accidents courced mostly by blewing rear tire had a large impact on how car and tire-makers handled tire pressure advice.
What I concluded of that affaire, is that the tires maximum load was given to high for the offroad looking Firestone tire , because the profile blocks that cover a part of the sidewall made the sidewall less flexing allowed then a normal car tire of same sises and AT-pressure. So not the wrong calculation in that time for P tires with power 0,5 in the universal formula, wich was patced by adding 10 % to the loads for SUV, and not going lower then 26 psi.
European ETRTO stops at 21 psi, but if you would have the to nature ideal formula, wich my calculation comes close to, you could even go as low as zero pressure if the calculation gives it.
In Carting and for verry light vehicles with oversised tires they even go as low as 18 psi or even 12 psi with no blowing tires.
Exampels I came by in time , Spider ( 3 wheels)& Westfield.
To my opinion in some cases they over-reacted.
As late as 2005 American TRA Stepped over to the 0.8 power that European ETRTO used since about 1970 for all kind of tires, but only for P-tires and XL//. The Ford/Firestone affaire played about 1990 to 2000. The closer the power to 1 the lower loadcapacity for the pressure, or the other way around the higher pressure for the same load.
So I am not planning to burn my spreadsheets , have to burn the computer for it.
Always advice to use a reserve for things like , pressure loss in time, misyudging or misreading of weight , misreading of pressure , incidental extra load or loadshifting , unequally devided R/L, etc.
โOct-28-2014 01:40 AM
โOct-27-2014 10:17 PM
Made you a list with yet another spreadsheet with my calculation so to my opinion the right load capacity's for the pressure .
Made it per tire and only LBS but one in KG and one in LBS.
โOct-27-2014 04:35 PM
jadatis wrote:
The E-load tires you now have only need little more pressure then the P-tires wich are B-load tires with pressure needed for the maximum load of 35 psi.
But when you search for the pressure advices, on same plate is mostly the Gross axle weight ratings ( GAWR) and GVWR ( V for Vehicle).
Then read from tires the maximum load ( googled and found 109 Loadindex wich is 1030kg/<>2260lbs a tire for P tire in 245/75R16) and check if it gives AT 80 psi on sidewall.
Then to make it complete give speedcode ( probably Q for up to 99m/h)
Then I will calculate the needed pressure for you with use of one of my made spreadsheets , In wich I use an even saver formula then the tire-makers use. Also with some reserve for towing.
I expect the outcome to be as low even as about 40 psi rear when towing. Front then can be even lower because GAWR front is mostly lower then rear and when towing front axle is lifted up a bit by the weight on the pin.
โOct-27-2014 01:52 PM
darsben wrote:
When you have weighed the truck you can then find the TIRE MANUFACTURERS chart that will give you the correct pressure for the tire based upon the weight.
โOct-27-2014 11:45 AM
โOct-27-2014 11:21 AM
โOct-27-2014 10:14 AM
โOct-27-2014 09:42 AM
โOct-27-2014 02:06 AM
โOct-26-2014 09:18 PM
โOct-26-2014 08:48 PM
โOct-26-2014 07:10 PM
john&bet wrote:
I lower the air pressure in my "E" tires on my 2500 to about 65 rear and 60 front when not towing. I up my front to 70 and rear to 80 when towing.
