EnjoyLifeButGod's avatar
Oct 30, 2016
Tow car. Flat towing
Hello all
New here but heard good thinks about this forum
I just got 90s S10 Chevy pickup
rear wheel drive, 5 speed
I was told by more than not that I should be fine flat towing
Anybody able to verify this?
I don't wait to damage trans. Nice truck.
Being a stick looks like the only things spinning are rear end and drive shaft.
Thanks.
  • There is a dinghy towing forum for this topic.
    I don't know about the 1990s, but when I was looking in the first part of the 2000's, the flat towable pickups with 5-speed manual transmissions were Ford Ranger/Mazda B-series using the Mazda source M5OD transmission, and Nissan Frontier. Any other 5-speeds were questionable with respect to lubrication of the output shaft bearing, as that shaft was above the level of transmission fluid. In normal driving, everything was lubricated by splash from the gears on the input shaft. On the Mazda M5OD, Ford wanted the engine run every 500 miles to relube the dry parts of the transmission.
    I've seen some unofficial recommendations for other transmissions about overfilling for lubrication, but I've seen nothing about the transmissions GM was using in that era. I know folks who have flat towed supposedly "untowable" Toyota 5-speed manual transmissions, but the tow distances after hookup have been on the order of 30 to 100 miles, so everything probably still has a good oil film before the end of the tow.
    The risk of towing an "untowable" manual transmission are mostly economic. It is not like an automatic that is likely to overheat and "explode" or catch on fire, it is more like the transmission will have a shortened lifespan, and your risk is cost of repair, or replacement with another transmission from the junkyard.
  • Hi and welcome to the forum!
    May I suggest you contact the moderator and have this thread moved to the section,"Dinghy Towing".
    Norm
  • I have no idea if it is flat towable or not.....but need to get your terminology correct. A "tow' vehicle is the one doing the towing, a "towed" vehicle is one that is being towed....hence the nick name "Toad".'
    No big deal and no disrespect intended.
    Ron
  • FWIW, I looked at the Remco website. They only go back to 1996.
    The 1996 S-10, 4 or 6 cylinder, RWD, MANUAL transmission needs a Drive shaft disconnect.
    jules6 may be correct, your truck is possibly NOT towable four down.
  • If it's the five speed manual it should be towable. Look under recreational towing in the OM.
  • I'm guessing it can be flat towed but, check the owners manual. That will give you the correct information.
    Not all manual transmissions can be dinghy towed.
    That's a nice truck and would make a great toad (towed).
