path1
Dec 09, 2015Explorer
Upgrading tires and wanting "softer" ride?
Going from "ST" 15 inch to 16 inch "LT". Right now I have load range E on "ST" tires and travel with 72 to 76 psi. Max is 80 psi.
Don't remember exact scale weight but load range "D" has enough weight capacity for my TT with a little extra capacity to spare, but not much.
We have rear kitchen that gives "back of bus" ride. Bouncing not to rough but more than I would like. Of course I would like to leave a glass 1/2 full on counter and it still be there when we stop.
Question about going to 16 inch LT tire, would you go load range "D" or "E"? or should I find inflation charts of tire I'm looking at and put in just enough air for the weight that I'm carrying, to get smoothest ride possible?
Doesn't load range in tires effect strength of tire? As in the bigger load range means a stiffer tire? And that would mean stiffer ride?
Any advice.
Any advice.
