BarneyS wrote:
rhagfo wrote:
Snip...
X2 to the Captain!
Before you can state just air to Max, you really need to know what your tires are carrying!
You really got to love those that air to the max, without knowing what they weigh, and what the carrying capacity of their tire is at max inflation.
Snip...
I have weighed my trailer several times both on the way to our snowbird site, on the way home and several time in between. I know exactly what it weighs.
My rig came with C rated tires. I run E tires on it and know precisely what the carrying capacity of my tires and axles is.
I stated my reasons for airing to the max. If you disagree that is fine but no need to try to put down those that do not see it your way.:R
Barney
Barney, didn't mean to offend, but Max is just that what is needed for Max load.
Well so you know what you weigh, you also state you went from from "C" rated tires to "E" rated tires, likely at a big gain in carrying capacity. These tires that have a higher carrying capacity are now aired to Max pressure of 80 psi. Without the numbers of the old "C" and new "E" tires, this isn't an exact statement, but unless the "E" tires are carrying at least about 80 to 90 percent of their max capacity, they are technically over inflated. This reduces the contact patch with the road, decreasing traction for both braking and handling.
Just as a follow up to the MAX pressure discussion. I had a neighbor that ran a couple of log trucks. After several years of tires getting cut to shreds and throwing caps he tried airing down his tires form the Max of 110 to 90 psi. He found that his tires lasted much longer, with far fewer rock cuts and he vary seldom lost a cap.
He also had electronic scales on the truck, and ALWAYS carried at MAX GVW of either 80,000# or 105,000# depending on trailer configuration.
