Community Alumni
Sep 04, 2015Not applicable
Tire Inflation Charts
Yesterday on the way home, I stopped at the scales. In round numbers, the front weighed 3,800 lbs. and the rear (dual) was 6,900 lbs. I was able to get both axles on the scale, so the front and rear did add up. The recommended pressure for the RV is 62 PSI front and rear. When I replaced the original Continental Vanco tires with Michelin LTX MS/2, I started out at 64 PSI and that seemed to be OK. Lately, I have tried a bit more pressure and I can feel that is too much. When I consult the inflation chart from Michelin, the recommended pressure for the actual measured weight on the axles is 50 PSI. I assume that is the minimum recommendation. The door sticker on the RV says 62 PSI, so roughly that is about 4,500 lbs. front and 8,300 lbs. rear. I will say that at the Winnebago recommended pressure, it does steer better and does better with cross winds and sharing close quarters with big trucks. I'd like to compare notes with others on their experiences with adjusting pressures up or down. Also; did switching tire types or brands cause you to experiment with tire pressures?
